1wg will not start
t-rex
Re: 1wg will not start
yeah new plugs,replacement coils n leads replacement cdi new battery,so SHOULD have a spark.
Check it. Should is no substitute for knowing and you'll have a little time before fitting the new carb rubbers.
t-rex
will do mate but back at work ,away for afew days
t-rex
she lives but the clutch is well and truly stuck,might even have to strip it out to unstick it
Cool - it runs.
Take the plates out and clean them, give the steel plates a roughing up with some emery clouth. Hopefully that will make it better.
t-rex
cheers mate you have been a real big help,thanks again
No worries - once the engine runs it feels like your getting somewhere :)
t-rex
that is very true just the clutch to do this weekend then TEST,then i will have to start on one of the two cars that need sorting,there is no rest for the wicked.
innit !!!
t-rex
just to let people know bike running really well went for test today, and you guessed it,it FAILED, on bloody fork seals & a dodgy rear tyre.
