Safe to set fork oil height with just a rear paddock stand?
265chemic
Bike owned: 98cbr600f,08cbr1000rr,90vfr400
Re: Safe to set fork oil height with just a rear paddock sta
Post by 265chemic »
Theres also a drain bolt at the bottom of the fork leg which you can use to drain most of the oil - bounce the forks a few times to get as much oil as you can out. You can then remove the caps and fill with the prescribed amount. I guess you could fill from the bottom too if you could make / adapt a suitable pressure filling system but it may be more effort that its worth.
