NC30 dyno 45hp :(
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Re: NC30 dyno 45hp :(
Post by krisztian_andre »
lizard821000 wrote:stop posting and get to some bars, mama sans for sale.
I don't bother the bars and they don't bother me.
marti
Post by marti »
I had an nc 30 that made 45hp on a dyno and it was traced to a bent inlet valve on 1 cylinder.
I would guess you have a similar problem, 1 weak cylinder
krisztian_andre
marti wrote:I had an nc 30 that made 45hp on a dyno and it was traced to a bent inlet valve on 1 cylinder.
I see. Going back to dyno shop to get my a/f ratio graph and after that it's valve clearance, ignition diagnostic and carb setup. How did you find out about the bent valve?
Neosophist wrote:After you've set the valve clearances and compression tested it you'll know if it's worn inside / valve are leaking.
krisztian_andre
I got the a/f graph and it looks like a mountain range.
krisztian_andre
The power curves were identical between the two runs with the major peaks and valleys corresponding. what I'm saying is that the variations doesn't seem to be random. Can someone show me a close to ideal a/f curve for a bog standard jap spec NC30?
Your bike is running far too rich - get some smaller jets in it for starters.
krisztian_andre
Question is, why is it so rich when all it's components from the exhaust to airbox and jets are standard? Can it be carbon deposits on the valves or a clogged exhaust? Carbs are clean btw.
It can be rich due to atmospheric conditions. What altitude do you live at? What is the fuel quality?
There is no doubt it is far too rich. So, you make it leaner..which will make it more powerful, more efficient, cheaper on fuel and stop killing plugs...
krisztian_andre
I at sea level high humidity, 34 C temperature. It has 115 118 jets now, what size and brand of jets should I get?
