Page 2 of 2
Re: 3TJ Direct wheel swaps
Posted: Thu Sep 06, 2012 5:15 pm
by Evilchicken0
They'd probably fit - you'll need a sprocket carrier though
Posted: Mon Sep 17, 2012 6:58 pm
by Evilchicken0
Somebody raided the penny jar :o
Posted: Wed Apr 17, 2013 9:42 pm
by Kurlon
Doing some digging, it appears modern R6 wheels are setup with the right rotor spacing to work. If you run 03-05 R6 rotors you can run any R6 wheel up to current, reading says the 5 spokers are lighter. Only trick will be custom axle spacers. I'm now trying to get my hands on a wheel to verify this with.
Posted: Thu Apr 18, 2013 1:11 pm
by Evilchicken0
Spindle dia is probably different too so you'll need a packer, unless you can get bearings and the hub tube to fit
Posted: Thu Apr 18, 2013 1:21 pm
by Kurlon
Evilchicken0 wrote:Spindle dia is probably different too so you'll need a packer, unless you can get bearings and the hub tube to fit
I'm hoping the R6 axle is larger, that'll allow for easy captive spacer design.
Posted: Thu Apr 18, 2013 3:03 pm
by Kayla850
They are- the fronts are 22mm and the rears are 28mm.
