new NC30 project! build started
Re: new project, think i got my work cut out!!
That's just screaming out for the busted panels to be removed and piled in the garage corner then a good paraffin Wash down before work begins, just bought a similar abandoned Neglected Nc that had been dropped then parked up in the guys garden for a couple of Months although not quite as rough looking as yours at moment once cleaned up you will see the potential is there Good luck .
- vfrman
- Bike owned: NC30, 1098s
Looks like a track bike to me!
- V4beermonster
No way fun road bike I think with the 750cc lump in it
- Bike owned: NC35
davethetrucker wrote:That's just screaming out for the busted panels to be removed and piled in the garage corner then a good paraffin Wash down before work begins, just bought a similar abandoned Neglected Nc that had been dropped then parked up in the guys garden for a couple of Months although not quite as rough looking as yours at moment once cleaned up you will see the potential is there Good luck .
Dont do the 750 mod I see a great build thread coming along
- V4beermonster
750 conversion out the pan guys not prepared to cut a frame. So think 442cc lump minter over winter project
Sounds interesting, keep us posted Phil
- iDemonix
- Bike owned: '92 NC30
Booo! Original 400!
- V4beermonster
Already got a nice original
- V4beermonster
Well pulled bike to pieces yesterday and this morning, all in very unloved nick but complete, bike is a cat c write off in 1990. So only on the road for 12 months in uk imported 1989. Apart from being very neglected everything seems ok so far my needed list goes like this, bottom rad,L/H switch gear, screen brace,reg/rect, infill panels,mirrors think that's it so far. Have checked engine on the bench cylinder compression is all around 200psi, valve clearances all check out too. Anything else I should check whilst on the bench?
- hannakournikova
What about reframing into a no categorised frame?
