another fzr400/600 question
fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Re: another fzr400/600 question
Just had a look at mine and remembered why i had problems with mine. The oil/neutral plug is green on the 600 motor and dark red on the 3tj. I had problems because i confused the plug with the fuel sender which on the 3tj is green. So make sure the oil/ neutral switch are pluged into the red plug.fzrtim wrote:I had this problem on my conversion. I seem to think the 4jh plug for the neutral and oil sender are the opposite colours. Simply swap them, the plugs are the same!
Failing that the oil sender could be faulty.
