will not rev past 12500
Re: will not rev past 12500
If the induction system is standard (std airbox, filter) then it would be running way too rich with 125's in the rear, may be contributing to your problem.
shokrabi
I see. I got my advice from Rick Oliver about which jets to use. The airbox has the flap cut off, the snorcle removed and a hrc style tray.
All of the induction mods will be your problem. Now that you've mentioned them I would say your bike is running lean!!shokrabi wrote: The airbox has the flap cut off, the snorcle removed and a hrc style tray.
You could increase the jet size (size depends on what sort of filter you're running), but you'll always have a lean mid spot when you do with those mods.
Best to...
Return the airbox to standard (or get another one in your case), use a standard filter, standard flap, remove the hrc tray, and use 118/120 main jets and your problems will disappear...
shokrabi
ok, thanks for all the help.
