Re: G-Force in Cycle World Article
Posted: Sat Mar 24, 2012 9:39 pm
I thought they all evolved around you, Mike....
http://www.400greybike.com/forum/
They Yamaha Rings are Chrome Plated and prefer to run against the cast-iron. We were seeing micro-welding on the ring faces against the NikaSil. So, we did indeed go back to the cast-iron, OEM liners. Also, at 57mm, we were not having any issues with boring through, like what occurs in the 58mm bores.magg wrote:A quick question if I may Mike, are you still using nikasil plated cylinders. The info on your web site suggestion you have gone bask to bore OEM liners.
