G-Force in Cycle World Article
RickOliver
Re: G-Force in Cycle World Article
Post by RickOliver »
I thought they all evolved around you, Mike....
Bike owned: VFR400
Post by magg »
A quick question if I may Mike, are you still using nikasil plated cylinders. The info on your web site suggestion you have gone bask to bore OEM liners.
g-force performance
Bike owned: VTR-250, VFR400RR,
Post by g-force performance »
magg wrote:A quick question if I may Mike, are you still using nikasil plated cylinders. The info on your web site suggestion you have gone bask to bore OEM liners.
They Yamaha Rings are Chrome Plated and prefer to run against the cast-iron. We were seeing micro-welding on the ring faces against the NikaSil. So, we did indeed go back to the cast-iron, OEM liners. Also, at 57mm, we were not having any issues with boring through, like what occurs in the 58mm bores.
Mike Norman
G-Force Engine Development
