Page 2 of 2
Re: Project GK76A.
Posted: Sun Feb 19, 2012 11:40 pm
by HalifaxMark
Thanks rgvsp, I've found the part number in one of the Japanese manuals hosted at graniterock (36740-33C00), so far a lot of 600 parts (36740-D00) are being thrown at me but hopefully I'll find something usable. :D
rgvsp wrote:Mark,
I've been doing a rebuild and you are correct that a lot of parts are used on other Suzuki's. I basically just check out the part number in the parts manual and then enter it on a Suzuki parts supplier website (such as
http://www.suzukipartshouse.net/pages/O ... ibrand=SUZ) and see what other models it spits back. Since the prices are usually crazy I check on Ebay first to see what used parts are out there.
Re: Project GK76A.
Posted: Fri Mar 16, 2012 9:42 pm
by HalifaxMark
Update! After a couple of weeks spent juggling my finances, ordering parts in and cleaning as I go I can finally post an update on my progress.
Courtesy of my friends and work colleagues I now have an engine minus sheared-off studs and wheels with new rubber on them. I also have a box of bits that include a new chain and sprocket set, replacement rubber-grommets to mount the fairings, a new air filter, HEL braided steel brake lines, a new rear brake-disc, Pro-bolt fairing & screen kits and air intake pipes (which I probably paid through the nose for but oh well.
After this weekend is over I should have the majority of this back on the bike, leaving only the carb's (which I want to strip & clean), the engine (which needs cleaning and maybe painting in places) and the exhaust system. My plan for the exhaust system is to get the down-pipes blasted in work and then sprayed in VHT paint, the end-can is going to be cut open, the dents in it are going to be knocked out and then I'm going to TIG weld it back together.
If all goes well I'll have pictures to post up on Saturday/Sunday.
I
Re: Project GK76A.
Posted: Tue Mar 20, 2012 5:43 pm
by HalifaxMark
Re: Project GK76A.
Posted: Mon Mar 26, 2012 8:29 pm
by HalifaxMark
After some confusion and a lack of labelling on my part,
I've realised that I have no clue as to what order the connectors that attach to the ignition coils go on in. Can anybody take a picture or explain which wire goes to which ignition coil connector please?
Re: Project GK76A.
Posted: Mon Mar 26, 2012 10:43 pm
by Variablevalves suck
The L/H coil is Orange and White feeds 1/4.
The R/H coil is Orange and Black/Yellow feeds 2/3.
Re: Project GK76A.
Posted: Sun Apr 08, 2012 6:32 pm
by HalifaxMark
Cheers Variablevalves suck, there's only 4 connections that don't seem to have a home now; the two coming off of the headlight wires, a short blue wire with a round connector that's on the cooling system just below the tank (sorry but I don't know the technical term for it
) and lastly a random black wire that comes off the the same wiring bunch as the ignition cables.
Other than trying to figure out the homes for these wires and despite another deadline for completion having passed, here's what else has been done on the bike:
•I've de-rusted and re-painted the headlight bracket and cannibalised the headlight that came with the spare set of fairings to complete me original one.
•I've de-rusted and re-painted the bottom left corner of the fuel-tank, it's a temporary fix until I can either buy a new one or get this one stripped and painted properly.
•The wiring loom has been in and out a couple more times now; I've settled for it running around the LHS of the air box and along the frame before spreading out at the front of the bike. There's just enough slack in the clocks' cables to allow the front-end it's full turning arc.
•I bought near enough a whole swinging arm off of flea-bay for the rear hugger, I now have a spare rear-shock (from an SP model I believe), link, dog legs and swinging arm. Not bad for £35 posted.
•And last but not least ive had the original downpipes blasted, exposing a hole on the outside join of one pipe to the connector and a small hole opposite this one on the inside. MIG'ing aorTIG'ing the inside hole will prove impossible due to its location and I've been advised to use something called "gum-gum" rather than attempt to gas-weld it. Does anybody have an opinion on this?
No pictures this time due to my PC's power-supply giving up the ghost.
Re: Project GK76A.
Posted: Sun Apr 08, 2012 6:43 pm
by HalifaxMark
I forget to mention that I've fitted a K6 rear shock, it drops straight in but there's no clearance between the link and the shock. I'm not sure if this'll be a problem so I'm planning on machining a very small amount of material away from my spare link to see if I can create some clearance.
As always, I'd appreciate your thoughts and opinions on what I've posted up. :)
Re: Project GK76A.
Posted: Mon Apr 09, 2012 1:08 am
by morris147
HalifaxMark wrote:I forget to mention that I've fitted a K6 rear shock, it drops straight in but there's no clearance between the link and the shock. I'm not sure if this'll be a problem so I'm planning on machining a very small amount of material away from my spare link to see if I can create some clearance.
I had to take a little off for it to fit. It really works well out on the track.
Re: Project GK76A.
Posted: Mon Apr 09, 2012 1:09 am
by morris147
Also Dont use Gun Gum, it will only last a couple of miles!
Re: Project GK76A.
Posted: Fri Apr 27, 2012 5:39 am
by donk
i had the same problem with my downpipes after shot blasting i had a couple of holes in the middle of the
4 into 1 i took them to a welding company and they cut the collector in half and tig welded a plate around the 4 downpipes from the in side and re tig welded the collector back on it was a mint job and it runs fine
