Page 2 of 2
				Re: Uk  spec NC30 mirrors Part numbers wanted.
				Posted: Thu Feb 09, 2012 1:38 pm
				by arsey30
				The reflector mounting is a metal bracket held onto the mudguard with 3 rivets, and bolted to the number plate mounting with an m6 bolt.
Not available separately, only comes with the mudguard.
				Posted: Thu Feb 09, 2012 1:48 pm
				by ibby4585
				Hi Dave.
I don't suppose you have a close up picture of this do you?
The exploded diagram on the partsfiche doesn't show it properly.
Kris
				Posted: Thu Feb 09, 2012 1:58 pm
				by ibby4585
				Posted: Thu Feb 09, 2012 5:29 pm
				by arsey30
				The top one is complete rc30, similar to nc but without the top extension bar.
The lower picture is nc30 but lower portion cut off and extended with a new piece of bar.
				Posted: Thu Feb 09, 2012 5:46 pm
				by ibby4585
				Ahh that's interesting, I didn't know there was a second piece that attached to the undertray.
Cool, Thanks Dave.
Kris
				Posted: Sat Feb 25, 2012 11:05 am
				by 3024E
				2nd piece.............
Uploaded with
ImageShack.us
				Posted: Sun Feb 26, 2012 9:05 am
				by arsey30
That does not look right, seems to be cut short.
This is an original bracket for number plate with reflector bracket rivetted to the underside of the mudguard.
				Posted: Sun Feb 26, 2012 2:18 pm
				by 3024E
				Genuine item mate, were do you think its cut?????????
  Yours is shown with the extra bent bracket for the reflector  !!!!
				Posted: Sun Feb 26, 2012 3:09 pm
				by arsey30
				They are one and the same,  your picture shows the reflector bracket that rivetts to underside of mudguard, so does mine.
Perhaps they are 2 piece and the bent part is bolted on, I will get some under side photos, but I think the lower bent part is welded to make a one peice reflector bracket. .
				Posted: Sun Feb 26, 2012 6:21 pm
				by arsey30
				This is how my friend's bike looks, and it seems a pretty original fit and finish, and is made just  the same way  the RC30 bracket is welded
I think yours has been cut and repaired, but of course as neither he or I owned our bikes from new, we cannot say what is correct.
If you do have an original bike can you tell me if the chain should be gold or steel colour,  the rear sprocket black or silver, and if a tin plate should be rivetted to the outside.
Thanks very much
Dave. Learning about NC30s
