QUIICKSHIFTER
petrolhead
Re: QUIICKSHIFTER
Post by petrolhead »
2strokepowerhouse wrote:can you use the dynojet push type quickshifter and wire it in some how or do you need to have one of these "power commanders"
Well all the unit does is kill the ignition for a split second .
I seen something before about wiring a shifter to the coils but not sure what that set up but will see if I can find some info on it .I think alot of the purpose of the wee box is gauge the time the ignition is cut ,
I will try and get some more info for you
Re: QUIICKSHIFTER
Post by Evilchicken0 »
You can wire it into the side stand cut out - it will cut the engine for a split second and then carry on.
petrolhead
Re: QUIICKSHIFTER
Evilchicken0 wrote:You can wire it into the side stand cut out - it will cut the engine for a split second and then carry on.
I have a box coming that works that way ,through the side stand switch ,think there is a few different wires on it with different timing's ..Just need to get a quickshifter now..
Could be a bit more head bashing done getting that sorted....lol
Re: QUIICKSHIFTER
Should be staight forward enough
2strokepowerhouse
Bike owned: 3TJ1,3TJ2,3TJ6,900ss
Re: QUIICKSHIFTER
Post by 2strokepowerhouse »
cheers for the info guys il have a look into this way of doing it
