Vfr400 Nc24 battery dies.
Bike owned: VFR400
Re: Vfr400 Nc24 battery dies.
Post by magg »
Was the rect/reg disconnected when you measured the voltage on the three yellow wires?
Weno92
Bike owned: vfr nc24
Post by Weno92 »
Does anyone know where i can find a new one at all?
Weno92
Post by Weno92 »
magg wrote:Was the rect/reg disconnected when you measured the voltage on the three yellow wires?
i disconnected the 3 yellow wire pins does the other connector need to be disconnected as well?
No thats fine, you'd be very unlikely to get 28v reading with it still connected anyhow.
New genny for a start, then you can test your reg/rec.
Electrexworld sell new ones for aroun 60gbp
Weno92
Post by Weno92 »
Okay so i have just found out that is actually the stator that has gone completely there is continuity between the wires from it and the frame so the windings are knackered.
So does anyone know where i can get a new one or second hand one like this one.
http://www.electrexworld.co.uk/cgi-bin/ ... 3aG17#aG17
its for an NC24 (obviously) :?
thanks
Weno92 wrote:Okay so i have just found out that is actually the stator that has gone completely there is continuity between the wires from it and the frame so the windings are knackered.
thanks
I don't understand what you mean, you posted a link to where you can buy it but you want to know where you can buy it?
Also the NC24 uses 2 types, only the very very early ones had that genny, most use the same as the NC30
http://www.electrexworld.co.uk/cgi-bin/ ... 3aG72#aG72
G72 type
Weno92
Post by Weno92 »
Haha yeah i just realised what i did :whistle:
I copied a link of a picture but when i was posting it i found one for sale on there haha!! Didnt mean to post the reply :oops:
i ordered one but im waiting for an M20 bolt so i can get the damn thing off!! i cant pull it for love nor money :P
Sorry guys haha! :sshh:
Weno92 wrote:Haha yeah i just realised what i did :whistle:
WHAT did you order?
theres 2, MOST NC24's use the same one as the NC30, G72 type, which is more expensive.
Weno92
Post by Weno92 »
I ordered the one that the link goes to on advice of my father. Apparently thats the one that it should have been but i dont know???
Weno92 wrote:I ordered the one that the link goes to on advice of my father. Apparently thats the one that it should have been but i dont know???
From that link
Outer Diameter: 102mm Inner diameter: 42mm Thickness through hole: 14mm
* Note: We also sell another generator for the following bikes:
You need to measure the existing one ideally.
The G72 type is most common (the link I posted)
You originally posted G17
Outer Diameter: 92mm Inner diameter: 35mm Thickness through hole: 18mm
Notice it's much smaller.
G72 is 75.00gbp
