3TJ Downpipe clamps
- Hogdigerdy Dog
Re: 3TJ Downpipe clamps
when you say a metal divider in the collector box do you mean the exup valve
do you have an exup valve
it's in the collector box (as in the bottom of this pic) you can see the exup pulley on the left and the valve seating sticks out the right
if you do and it's not well enough adjusted then they make the type of sound you mentioned and rattle like a good un
FZR400
- Bike owned: Yamaha FZR400 RR 3TJ
I see! Because it is an aftermarket one the EXUP system has been completely removed as pic:
But the collector part just before the final piece of pipe has the loose piece of metal in, i assume it was to seperate the flow until the very last point but im not too sure.
- Hogdigerdy Dog
if your lucky you might find once you get the pipes off, the offending bit of metal will come out the fat end of the pipes
as for the header nuts use some plu-gas on the studs and leave overnight then reapply before trying to remove the nuts, if the studs come out the engine then all well and good, your probably better off replacing them any way
you can use a bit of heat on the nuts but only enough to heat the nuts not the studs and remember if you use a releasing agent (plus-gas or whatever) it's flammable
EDIT do you still have the exup servo attached, under the tank, left side mounted on-top the engine casing (black thing) if so your better off looking for a decent set of headers with exup and buying the cables, for that matter it'd be cheaper to get another set of headers, servo and cables than buy a set of aftermarket pipes and you wont have to scream it's nadjers off to get it to go round town
FZR400
Good advice! it still makes the whirring noise when i turn the ignition on so i guess it does, ill keep my eye out for a set on the bay.
BTW nice spot EC on the PB Forum, my bike was said to be an SP in the recent mag but its not
The 3TJ 02 SP colour scheme is nice though, I like it more than the usual dark red / white
Are you near London then ????
FZR400
I like the colour scheme but unfortunately the fairing is in really bad condition so it doesnt look that great close up.
I work in Chiswick and live just outside West London so im usually around for those sort of rides!
I work in Southwark and live in Euston ... it was early in the morning so I didn't go !!!
the fairing lowers don't usually cost that much on Das Bay , I can tidy them up a bit if you want
- Davez29
- Bike owned: NC29 forever
Can I say that I have had the same problem with a set from sandybike spares for my cbr400. I did not overtighten ( I do know to keep it parallel to the head) but the header clamps distorted and snapped like I had overtightened. The stainless parts that keep the 4 into 2 have either cracked or dropped off, this happened just as the two year warranty ran out and they would not replace them.
I got the clamps welded up and they have been fine since, I have to get the final one that was not snapped done now as I noticed it is also cracking and get some brackets welded on between the 4 into 2.
I notice they now sell an "upgraded design"
