upgrading a jap nc30,s headlamps
Re: upgrading a jap nc30,s headlamps
Sheesh.. there's an award for everything it seems.Neosophist wrote:philips Xtreeme are really AWESOME bulbs.. I can't stress how good they are over standard bulbs (which is why they always win What Car bulb of the year.
Might have to look into getting some.
- Bike owned: NC30 Type 7
is there a guide to modifying JDM headlight to accept a H4 55/60 bulb. Mine have the tabs cut off the bulbs but it's not a satisfactory fit really
Cammo wrote:Sheesh.. there's an award for everything it seems.Neosophist wrote:philips Xtreeme are really AWESOME bulbs.. I can't stress how good they are over standard bulbs (which is why they always win What Car bulb of the year.![]()
There really awesome compared to cheap H4's though... 20gbp a set and there so much brighter and a clearer light and last a long time..
Modifying the headlight is fairly easy.
Take it out of the the bike.
Drop a H4 in and see where the tabs want to sit and using a dremel or small file (dremel is easy takes 2 seconds) cut a bit of the plastic away so the tabs can fit in properly.
- Bike owned: VFR400RK, VFR750FK, VFR750FH,
John at VSource had a very good guide to modifying the headlamps to accept H4 bulbs. As well as cutting the the plastic away the retaining clip needs to be moved to a different hole. Relatively straightforward job and well worth it. I fitted my NC30 with Philips Blue Vision bulbs many years ago.
found it, cheers!
http://webpages.charter.net/bpeloquin/H4mod.html
I'll add that to the list of little mods!
- Bike owned: NC35
I work at an auto electricians, and we highly recommend the Philips extreme, you can get em in either 80% or 100% brighter.
So much brighter than originals.
I'll see how cheap I can get em.
