Can't Find Neutral NC30
Andy666
Re: Can't Find Neutral NC30
Post by Andy666 »
JIGGLYB4LL wrote: And I can hardly ever get neutral when it's running so if I ever wanna stop and hop off for a second I always have to turn her off.
Doesn't cause any major issues, just got used to it but if u find and easy fix let me know!! :pray:
As Porndog says, while at a standstill, give the throttle a little blip as you snick up into neutral. Takes a couple of goes to get used to, but should work. If you're still rolling to a stop, it should be easier to find neutral without the need of a blip.
JIGGLYB4LL
Bike owned: cbr125, NC30
Post by JIGGLYB4LL »
Cheers mate, I'll give it a go :)
Bike owned: VFR400
Post by magg »
What are using to select the gears if the lever is broken. Neutral light switches can be a bit temperamental, at least mine is, and therefore light does not always illuminate when in neutral. The clutch also tends to drag enough to make finding neutral difficult when engine is running, I find it best to try for neutral before the bike comes to a stop. There is a disc with six deep notches for the gears and a shallow one for neutral, under the cover into which the gear shift shaft feeds.
RegionX
Bike owned: VFR400 NC30
Post by RegionX »
magg wrote:What are using to select the gears if the lever is broken.
Half a gear lever ;) . Thanks, do I have to drain gearbox oil to get in there?
porndoguk wrote:its normal you have to blip the throttle upto about 8k and drop it into neutral as the revs drop.
its the joys of owning a honda :D
8k!?
2-3k is fine!!
i find if I hold mine at 3k it slips in easy
RegionX
Post by RegionX »
Ok bump started, got neutral while rolling and now it finds neutral easy but it wont start, needs to get these carbs sorted...
porndoguk
Post by porndoguk »
8k!?
2-3k is fine!!
:lol: probally an over thought but what i meant wasnt rev the bollocks off it and bounce the limiter.
Bike owned: VFR400
Post by magg »
When removing the external gear change mechanism there will be a little accumulated oil but that's all. Bigger problem is you have to remove the water pump so if you can now find neutral I would not bother, unless you have more problems later on.
Peter.H
Post by Peter.H »
I've been at the TT all week sat in traffic unable to get the nc in to neutral. This thread has saved me stalling it every time I want neutral! Amazing. Small blip of throttle and slots straight in.
Sent from my HTC One_M8 using Tapatalk
