Page 2 of 2
Re: bike cut out help!
Posted: Tue Nov 01, 2011 4:07 am
by magg
If the noise is more like a very fast clicking it sounds like a faulty starter motor relay and/or a flat battery.
Posted: Tue Nov 01, 2011 3:20 pm
by iDemonix
We need more (and clearer) information to diagnose your problem.
Posted: Tue Nov 01, 2011 3:38 pm
by Jashdown
And how about you acknowledge some of the suggestions other members are making? 4 people have said the vacuum hose and you haven't even responded to them, instead, you check other problems.
If it randomly stopped, I would be inclined to think a fueling issue. So check the vacuum hose.
If you tried to restart the bike and it would turn over but not start, then it's a fueling issue, obviously the battery is working fine. If there is a buzz sound when you press the starter, it will be a flat battery. If it's clicking it will be the starter like someone already suggested, but the starter won't be the cause of your bike randomly cutting out.
Check the fueling like everyone has suggested.
Posted: Tue Nov 01, 2011 5:26 pm
by joshmega
it was the regulator fixed now
Posted: Tue Nov 01, 2011 7:32 pm
by rob b
Hi.
How did you know it was the reulater.
Thanks.
Rob.
Posted: Tue Nov 01, 2011 7:35 pm
by joshmega
the battery was fine but it would keep charge so i guessed that what it was but also the garage i took it too also thought that was the proplem
Posted: Tue Nov 01, 2011 7:39 pm
by rob b
Thanks just i'm haveing the same problem.
But I took the reg of & unpluged it & one of the yellow wires in the plug was looked like it was all burnt & the same on the pin on the reg were it plugs in.
Hope this makes sense.
Any ideas?
Thanks.
Rob.
Posted: Tue Nov 01, 2011 9:54 pm
by magg
Dud rect/reg will cause over or under charging of the battery, highly unlikely to cause random engine cut out. If the battery was fine then the charging system including the rect/reg should have been ok. Again how do you know it was the rect/reg.
Posted: Tue Nov 01, 2011 11:57 pm
by joshmega
The battery I tested and was fine but it wasn't being recharghged when in the bike so it is obvious that it was the regulater that had stop working as the battery was not regarching itself
Posted: Wed Nov 02, 2011 2:17 am
by magg
With a dud rect/reg the battery had to be flat at some point, which was not mentioned in your list of symptoms. I would keep an eye on the battery voltage just to be sure.
