rearsets and damper
				wedge
Re: rearsets and damper
well you could have a point........aye up here in perth we do ride harder....lol..i was only asking what kit you can get for the fzr..but i do fancy rearsets,i really bought it to take the piss out of my mates on there 600cc and 1000cc....i really want to trick it out abit but also show them(mates) how right yamaha got it when they built 3tj.
If your showing them how right it was then your better off not having the damper. Overhaul the standard forks, R6 shock conversion, use a later brake master cyclinder, braided hoses, HH pads and fit some supercosa's ... your good to go.
				edsashed
hi evil i will try it without, i used to have one on my other 400,but that only slapped a little when racing at the isle of man,and only on the bit from ginger hall to ramsey,im planning on doing the thunderbike series next year after reading kayla had got it sorted for them to be allowed,so maybe on short circuits it will be ok cheers for the reply though
No worries - keep us informed ... with pictures
				wedge
its got braided lines.....but what do you recommend for the front springs,make,oil etc????.im looking at the r6 conversion,but have to contact the dude sells them cause what i don't know is how much it alters the rear ride height.
The R6 forks stick up through the top yoke quite a way and just miss the screen ... not sure about the mirror brace.
				Taggyd
the rear height wont be changed if you put the forks throught the yokes so that there is the same length as the fzr forks 'below' the bottom yoke. but they will stick up a lot! a set of sp forks with springs set to your weight would be a good start, oil will depend on you and will need to be tested. a starting point would be standard air gap but in a heavier oil.
				wedge
thanks i was thinking sp forks on front...but what i was talking about is the r6 rear conversion..if it jacks the rear etc.
Opps - I see.
The R6 shock is opposite to the forks in that it's too short and needs an extension piece made up. I think they're height adjustable though - Kayla makes the extension piece and probably knows about the ride height too.
http://www.projection-components.co.uk/ ... ts-1-c.asp
Nice T shirts too
Nice T shirts too
				wedge
my mate had a 3tj....back early 90's he had to get the jack up kit....so i have been looking at kayla's r6 shock conversion...just wondered if when making it he added extra to jack it up or if you also need his dog bones aswell....i'll ask him.
