temperature problem on my nc30 :/
Re: temperature problem on my nc30 :/
If this is the case then remember the broken pin will still be floating about in your sump, id be looking to find and remove it ASAP!CRM wrote:if its still and nothing happening then i bet your water pump has broken off its locating pin
JIGGLYB4LL
- Bike owned: cbr125, NC30
Oh crap
Wanted to used my bike tomo...guess I better get it looked at first!!!
just reading the first post again - it does sound like a pump failure. I would not want to ride it like it is, get it sorted!
- CRM
yep mine was lodged inside the sump strainer. i was lucky.
if the level doesn't noticeably drop or move much under revs then i really wouldnt be running it until you know whats going on.
why not see if one of the local lads / pervs can pop around and sort it out for you. at least have a look and put your mind at rest. some great people on here who go above and beyond for others.
JIGGLYB4LL
Doesnt feel me with confidence!!CRM wrote: why not see if one of the local lads / pervs can pop around and sort it out for you.
Lol
Ok, I've decided I'm sacking my 4yr old for the day tomo and gonna have a go myself. I like getting my hands dirty and I reckon it's worth a try...
I can't wait til the weekend, the suns shining!!! I can hear her calling to be let out!!
Keep everything crossed for me...I may be on here again tomo in tears and begging someone to come save me!!
Well drain the oil and get the water pump off and if its fucked then the sump has gota come off to find the pin so go get yourself a sump gasket, given your location rick oliver has got to be your best bet. Then you need a new water pump, agian i reckon rick oliver will be able to sort you out. With any luck she'll be back together by the weekend :)
- CRM
I trust you meant "Fill" and not "Feel" lolJIGGLYB4LL wrote: Doesnt feel me with confidence!!![]()
Lol
JIGGLYB4LL
- CRM
bad girl !
you will fit in just fine around these parts then
JIGGLYB4LL
No no!!!
I'm a good girl!!
Oh jeez...I'm off before I dig a bigger hole...
I'm a good girl!!
