Page 2 of 3
Re: Bad Running - 3TJ Answer and now I'm buggered!
Posted: Wed Sep 14, 2011 3:15 pm
by Taggyd
failing that, ive got a 6lb sledge that might help! :twisted:
Posted: Wed Sep 14, 2011 4:15 pm
by MarkT
Yes thanks for that, I do think they are fully home as when you push em they do seem to "lock" in place?
Posted: Wed Sep 14, 2011 7:23 pm
by Taggyd
sounds as if they're home ok, mine gave a def 'clunk' when fitting. i may have a set of 3en1 rubbers but i think there was a difference in their height, and again i dont know if they are even any good.
Posted: Wed Sep 14, 2011 7:42 pm
by Evilchicken0
I think there are 3 possible things that could be wrong
The carbs aren't home or the clips aren't done up properly
The rubbers are shot
They're not 3TJ rubbers - which is why I said to check the part numbers on them.
I don't thing 1WG rubbers will work. 4JH rubbers might but they could be longer ... or shorter so you might have a problem with the airbox fitting under the tank
Posted: Wed Sep 14, 2011 7:59 pm
by MarkT
Taggy wrote:sounds as if they're home ok, mine gave a def 'clunk' when fitting. i may have a set of 3en1 rubbers but i think there was a difference in their height, and again i dont know if they are even any good.
I would love to talk with you about your set, I'll send you a pm!
Posted: Wed Sep 14, 2011 8:20 pm
by MarkT
Evilchicken0 wrote:I think there are 3 possible things that could be wrong
Even though I am away from the bike I know that it says 3TJ on the lip of the rubbers but there is other writing aswell.
Please note that at the moment the clamps are not used because they are being removes so often. A good forum member races without the clamps as all is well
Posted: Wed Sep 14, 2011 9:48 pm
by Taggyd
i'll have a look at what mine say, like i said they may be 1wg but then they may be something different!
Posted: Wed Sep 14, 2011 9:51 pm
by MarkT
Taggy wrote:i'll have a look at what mine say, like i said they may be 1wg but then they may be something different!
Thank you so much!
Posted: Thu Sep 15, 2011 1:24 pm
by Evilchicken0
Put the clamps back on :o
It might work for a one person but they're there to seal the rubbers to the carbs ... the very problem you have now. At least it proves Yamaha's design works.
Posted: Thu Sep 15, 2011 2:59 pm
by MarkT
Yes ok, I though about modifying a bit of the clamp so it would do up tighter, dealer said no but I reckon that's where the leak is as all four seem affected? What do you think?
(I guess mr yamaha had a reason the clamps are like they are, probably not for overtightening!)!
