Bad Running - 3TJ Answer and now I'm buggered!
Taggyd
Re: Bad Running - 3TJ Answer and now I'm buggered!
failing that, ive got a 6lb sledge that might help!
MarkT
Yes thanks for that, I do think they are fully home as when you push em they do seem to "lock" in place?
Taggyd
sounds as if they're home ok, mine gave a def 'clunk' when fitting. i may have a set of 3en1 rubbers but i think there was a difference in their height, and again i dont know if they are even any good.
I think there are 3 possible things that could be wrong
The carbs aren't home or the clips aren't done up properly
The rubbers are shot
They're not 3TJ rubbers - which is why I said to check the part numbers on them.
I don't thing 1WG rubbers will work. 4JH rubbers might but they could be longer ... or shorter so you might have a problem with the airbox fitting under the tank
MarkT
I would love to talk with you about your set, I'll send you a pm!Taggy wrote:sounds as if they're home ok, mine gave a def 'clunk' when fitting. i may have a set of 3en1 rubbers but i think there was a difference in their height, and again i dont know if they are even any good.
MarkT
Even though I am away from the bike I know that it says 3TJ on the lip of the rubbers but there is other writing aswell.Evilchicken0 wrote:I think there are 3 possible things that could be wrong
Please note that at the moment the clamps are not used because they are being removes so often. A good forum member races without the clamps as all is well
Taggyd
i'll have a look at what mine say, like i said they may be 1wg but then they may be something different!
MarkT
Thank you so much!Taggy wrote:i'll have a look at what mine say, like i said they may be 1wg but then they may be something different!
Put the clamps back on
It might work for a one person but they're there to seal the rubbers to the carbs ... the very problem you have now. At least it proves Yamaha's design works.
MarkT
Yes ok, I though about modifying a bit of the clamp so it would do up tighter, dealer said no but I reckon that's where the leak is as all four seem affected? What do you think?
(I guess mr yamaha had a reason the clamps are like they are, probably not for overtightening!)!
