exhaust again
Re: exhaust again
I'm not using it mate. if he wants to get rid of it then I'll drop it back at his asap
The Novice
Bike owned: NC23 NC30 CRM250
Re: exhaust again
Post by The Novice »
he said if you get it back to him first he will sort send it out for me. thanks for the help -
before the hassle of getting it to geoff tho, can i just check the dimensions, bolt to bolt, slip on int diameter and bolt holes sizes pls.
Just want to check its going to fit before i buy it, i will check the quill can later but am sure its 77mm centre to centre and the inlet is 70mm so the adapter needs to just be wider than 70mm, i think my exhaust accepts 50mm slip on.
The Novice
Re: exhaust again
I have sorted it now.
gareth91
Re: exhaust again
Post by gareth91 »
What diameter is the flange on the standard nc23 header?
