Electrics failing? NC30 Wont start :(
iArGod
Re: Electrics failing? NC30 Wont start :(
Post by iArGod »
Still no luck getting the engine running atleast :(
Have tried few times to bump start it but its horrible to push it up and down a bit.
Is there ANY other way to start an engine without electrics?
Bike owned: VFR400
Post by magg »
Do any of the lights etc work? If you have a charged battery and nothing works, sounds like the main fuse has blown. To be sure the battery is charged, measure the battery voltage when you turn on lights etc. Battery voltage needs to stay above 12 under load.
iArGod
Post by iArGod »
One of the contacts to the reg/rec must have had a lose connection, cleaned the crap off it and shes back up and running :)
Thanks for the input lads!
you can run a bike without a reg rec though - so something else must be at fault?
iArGod
Post by iArGod »
Its running perfectly fine at the moment, i took it for a long ride and i didnt have any problems!
Starts first time again.
