Nc24 battery Not holding charge
- Bike owned: CB-1, MSX125
Re: Nc24 battery Not holding charge
Sad to say, f the charging system has a fault bad enough to melt the alternator plug, then rewiring it and fitting a new battery is very unlikely to resolve the issue.sp00ka wrote:Iv just been given a multi meter and been seating on line how to
Bloody use the thing :-/ should have checked my mail on here 1st , I'll test it Saturday and be back in touch , just hope it's the battery faulty and nit the regulator Thanks ,
Go through the checks, if anything is wrong then fix it before riding, or you will be fixing it twice.
Done all checks , charged battery full on the 29th and it read 14,34 on the 30th it read 13,37 ,
All the yellow wires I found had melt into one , I didn't notice this before because it was covered by black casing, so I cut them back and done the tests,
A&B B&C A&C all read between 45.5 to 46 v ,
Then I solided all 3 wires together and did the test on the battery , it read between 13 to 14
After I took the bike for a ride, it ran a lot smoother, it sat idle better then it ever did ,
It must have Been the wires melting into one :-/ but can't under stand why,
I went out for a hour on the bike and did a test on the battery again and it read 13.8 ,
I did all test exactly how u asked
- Bike owned: VFR400
The melted plastic connector shell was probably the result of poor mechanical contact between the male & contacts of the connector. Had the same problem myself, once I replaced contacts & connector shell all has been ok. I think the cause of the problem is that original contacts after 20 years either loose their tension and/or become contaminated with road crime causing a resistive junction. Resistive juction generates heat when current flows resulting in a hot spot that melts the plastic, which will eventually allow the yellow wires to touch.
You soldered them all together? Or you mean you repaired each one...sp00ka wrote:Done all checks , charged battery full on the 29th and it read 14,34 on the 30th it read 13,37 ,
That didn't make since what I put , sorry ,
I soldered each one separately
cuz the plug had melted I had no choice but to cut wires ,
