Thundercat 3TJ
				MrTadSlow
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
Re: Thundercat 3TJ
Kayla.... How many links in that there 520 chain ? & is it rivet or clip type Please.
						- Kayla850
- Bike owned: Sunn Tzar S2
Re: Thundercat 3TJ
I don't know, sorry. I bought a 120 link 520 MX non o-ring chain and cut it to length, plus I've got a TRX arm fitted to my bike which is a tad longer than the 3TJ one. I'm using a split (clip) link with no problem.MrTadSlow wrote:Kayla.... How many links in that there 520 chain ? & is it rivet or clip type Please.
www.projection-racing.com
www.pjcfasteners.com
				StreetFZR
- Bike owned: 3TJ 4/6 TURBO Streetfighter.
Re: Thundercat 3TJ
This is a good point Alex, could anybody elaborate on this one??Alex. wrote:If the TPS is on the carbs and the carbs, loom and CDI from the Thundercat are used, why would there be a problem? If the loom from the 3TJ was used, I could see the issue.
Surely the TPS would connect to the loom and the loom to the CDI. If the TPS is on the carbs, then it will take the position from how much the cable has pulled the TPS round.
Alex.
I am going to be putting basically a thundercat inside my 3TJ. Not alot of 3TJ left to be honest.
- Kayla850
Re: Thundercat 3TJ
It'sshouldn't be an issue if you're using all the Thundercat electrics like Alex says. I don't know why it was brought upStreetFZR wrote:This is a good point Alex, could anybody elaborate on this one??Alex. wrote:If the TPS is on the carbs and the carbs, loom and CDI from the Thundercat are used, why would there be a problem? If the loom from the 3TJ was used, I could see the issue.
Alex.
Re: Thundercat 3TJ
I brought it up although I was only pointing out what might happen and an easy solution if it did.Evilchicken0 wrote:If you take engine, carbs, downpipes, loom, clocks .... the only thing that might be a problem is the throttle position sensor on the carbs if you use the T'Cats CDI although it should fire up the rev counter might flick to 8k repeatedly. If this does happen use a Foxeye CDI.
Use the carb holes and snorkel from a Foxeye airbox cut 'n' shut with the 3TJ's.
- Kayla850
Re: Thundercat 3TJ
Ah, I see. Ta :)Evilchicken0 wrote:I brought it up although I was only pointing out what might happen and an easy solution if it did.Evilchicken0 wrote:If you take engine, carbs, downpipes, loom, clocks .... the only thing that might be a problem is the throttle position sensor on the carbs if you use the T'Cats CDI although it should fire up the rev counter might flick to 8k repeatedly. If this does happen use a Foxeye CDI.
				StreetFZR
Re: Thundercat 3TJ
Thanks for clearing that up Kayla and thanks also to Evilchicken0 as well
				StreetFZR
Re: Thundercat 3TJ
Ok I have the engine and all other parts home now but it needs the downpipes. The rest looks good frame is in very good condition but will be sold on.
Anybody know if any others are interchangeable??
Re: Thundercat 3TJ
Foxeye ???
						- Kayla850
Re: Thundercat 3TJ
You'll have trouble giving a Thundercat frame away to be honest. I've had two 4JH frames I had to give to the scrap man. A steely racer might give you something for it, but because they're pressed steel (and really f-ing heavy!) nobody wants themStreetFZR wrote:Ok I have the engine and all other parts home now but it needs the downpipes. The rest looks good frame is in very good condition but will be sold on.
