fzr 400 1wg tyre size or 17" swap
- Kayla850
- Bike owned: Sunn Tzar S2
Re: fzr 400 1wg tyre size or 17" swap
Cool, post some pics of the build upj4cko wrote:Ok thanks for confirming the fitment. I'll probably go with the xjr, as I can get the brake setup too. Plus I'm making a track bike, so the bigger rear brake isn't a bad thing really
www.projection-racing.com
www.pjcfasteners.com
Do you have any info on how to mount the brake caliper? Does the caliper bracket still fit on the spindle between the swingarm and the wheel?
Kayla, is the XJR brake rotor mount such that a custom lightweight rotor could be made to allow one to retain the FZR brake assembly? Got a friend who just picked up an US 88 FZR for racing and trying to find the easiest way to slide a 17 in there.
- Kayla850
I don't think so, the XJR disc is 240mm and the hub is huge compared to the FZR hub so I think the FZR stuff would catch on the XJR hub. This is all from memory because I haven't got any Yam stuff left nowKurlon wrote:Kayla, is the XJR brake rotor mount such that a custom lightweight rotor could be made to allow one to retain the FZR brake assembly? Got a friend who just picked up an US 88 FZR for racing and trying to find the easiest way to slide a 17 in there.
