GK73a Advise Needed Float Height & How To Install The Airbox
Variablevalves suck
Re: GK73a Advise Needed Float Height & How To Install The Ai
Post by Variablevalves suck »
Ye if you look at the needle no.s i posted the last no. is the groove notch from the top.
Mazzerdod
Post by Mazzerdod »
That's cool I never knew that how did you learn something like that?
Progress on the bike..... I was at the unit yesterday working on my FZ and I had my mate take the carbs off the SP and showed him how to set the floats and needle heights he's learning!
But he put it back together and when it fired it tried to rev out so I hit the kill switch I think he has fluffed something putting it back together probably the throttle cable so I didn't get chance to try the new setting.
Oh and your trick with the air box works a treat!
Do you know were we can get an air filter having difficulty finding one or can we use a filter from another model?
Variablevalves suck
I spent 4 years as a mechanic after leaving school! + im getting old now so have 20+ years of bike under my belt and spent a long time around racing scooters that run Amal carbs.
I edited the needle numbers as i had'nt put the last digit on.
Mazzerdod
Post by Mazzerdod »
That explains it, funny I trained for 3yrs as a mechanic but that's no longer my bread n butter.... although I always have something on the go cannot resist getting the spanners out :grin:
Armi400
Bike owned: GSXR400RRSP/SRAD 600
Post by Armi400 »
Is'nt there a sticky on here, which says flost hieghts should be set at 20mm???
Mazzerdod
Post by Mazzerdod »
Hi I think 20mm float height refers to the GK76 model this thread refers to the GK73a SP which has a float height of 14.6mm.
Armi400
Post by Armi400 »
Mazzerdod wrote:Hi I think 20mm float height refers to the GK76 model this thread refers to the GK73a SP which has a float height of 14.6mm.
Ah........thanks for clearing that up for me.....really should pay more attention......lol
Reacently replaced all o rings and set float heights, installed back and then read this......
Just waiting on a fuel tap rebuild kit and see if i can get her started up......cheers!
Mazzerdod
Post by Mazzerdod »
I have just finished rebuilding the carbs on this bike.... the idle mixture screw setting and carb balancing are critical having said everything is important!
Good luck.
