Newbie in need of help!
- spooky
- Bike owned: nc24
Re: Newbie in need of help!
Oh and get it out of the hedge.
Carcass
- Bike owned: Srad750, Nc29
The Big Cir clip was by the disc , i removed that and removed the small cir clip inside the hub and pulled out the entire hub! here's some picsNeosophist wrote:is that a circlip by the disc?
http://i46.photobucket.com/albums/f115/ ... ate002.jpg" onclick="window.open(this.href);return false;
http://i46.photobucket.com/albums/f115/ ... ate003.jpg" onclick="window.open(this.href);return false;
http://i46.photobucket.com/albums/f115/ ... ate004.jpg" onclick="window.open(this.href);return false;
http://i46.photobucket.com/albums/f115/ ... ate006.jpg" onclick="window.open(this.href);return false;
Also thought id upload a pic of the bike project {if anyone has a wiring loom spare please let me know}
http://i46.photobucket.com/albums/f115/ ... ate007.jpg" onclick="window.open(this.href);return false;
Carcass
LOL! , it was only in the hedge because i had to strip it down to get the exhaust off {collector box was in pieces} which ive had to weld the remains back together!spooky wrote:Oh and get it out of the hedge.
- spooky
- Bike owned: nc24
microfish 27 shows the rear assy. looks like the whole lot has to come off looking at it, try angling the disc around the wheel hub bit before taking it apart. the sprocket comes off if you do that so the disc might do the same. just an idea!
- spooky
- Bike owned: nc24
Any luck yet?
Carcass
Afraid not im still stuck at the same point {as the photos} took it into my local mechanics who said if i grind the old disc off they could try using there steel press, but im wondering if that would just destroy all the bearings inside.spooky wrote:Any luck yet?
- spooky
- Bike owned: nc24
Mate, have you not removed the 4 bolts holding the disc on the hub
fastdruid
Tbh if it's stuck on like that the bearings may be ruined anyway.Carcass wrote:Afraid not im still stuck at the same point {as the photos} took it into my local mechanics who said if i grind the old disc off they could try using there steel press, but im wondering if that would just destroy all the bearings inside.spooky wrote:Any luck yet?
Druid
- spooky
- Bike owned: nc24
Get a hot air gun and heat the alloy bit, then give it a good whack.
The bearings are prob meant to be a good tight fit.
Carcass
Hi all sorry for the belated reply.
Well I've been running around all over the place these last few days with a print out of the parts fiche, spoke to mechanics, Honda {they didn't have a clue} and then a few people at High Beech{bikers tea hut in the forest} only to get a phone call from my father to say he'd done it after looking at it for five minutes!!
So for everyone planning on doing this I've worked out {well my father did} how to do it.
When you get the hub out, after taking off the rear sprocket and cush drive take out the large cir clip inside the hub you will see a large lock nut washer type thing.
You then prize off the large lock nut washer type thing with a screwdriver and there is a thin metal clip {like a keyring} around the spindle, take that off and the spindle slides out!!!
{pics to come later}
Thank you everyone for your input and advice {thanks Spooky for the links} I hope all my troubles will help anyone out in the future.
Finally i can start to build the bike up :D
