Page 2 of 3
				Re: 3tj wheel/brake issue....
				Posted: Wed Mar 16, 2011 2:26 pm
				by Taggyd
				i think it's 10mm aswell!
				Posted: Thu Mar 24, 2011 10:09 pm
				by Evilchicken0
				From the hub matiing surface to the outside of the disc carrier = 9.37mm
				Posted: Mon Mar 28, 2011 4:05 pm
				by alext
				now heres a question...
have I got the right calipers???......
the ones I have, have 4 pistons, 2 big and 2 little...
are they the correct ones????
ayone got a link to a parts diag for a 3tj??
ALex.
				Posted: Mon Mar 28, 2011 4:24 pm
				by Kayla850
				alext wrote:now heres a question...
ALex.
If you've got standard 3TJ forks in I don't think it's possible to have the wrong calipers. I think all of the 83mm Yam calipers are the same.
Can you post up a pic of the casting marks on your wheel?
				Posted: Mon Mar 28, 2011 5:45 pm
				by Evilchicken0
				Are the forks on the bike ???
If not maybe you have the fork bottoms rotated - the spindle goes form right to left as you sit on the bike.
				Posted: Mon Mar 28, 2011 10:25 pm
				by cagiva996
				if you need a set of 3tj discs ive got 2 or 3 pairs hanging around,pm me if you need some.
				Posted: Tue Mar 29, 2011 10:20 am
				by Taggyd
				look in the sticky for manuals, pretty ure there's a caliper diagram in there. they should be sumitomo (or however you spell it) .
				Posted: Tue Apr 12, 2011 8:59 am
				by alext
				ok next issue I have is at the back !!!
having got a 3tj rear brake off Taggy (cheers!) I need to fit it and the spacing is quite different for the caliper carrier, so I need to make up a spacer and also something to reduce the 3tj's caliper carrier from a 20mm axle down to the 1wg's 17mm.
inside the 1wg sprocket carrier there is a spacer that spaces the carrier out that fits inside the 20mm id bearing in the carrier.
I could easily modify one of these to do what I want - does anyone have one lying about they'd be willing to part with?
Ta
ALex.
				Posted: Tue Apr 12, 2011 9:28 am
				by Evilchicken0
				Why not look at going the other way round this problem and use the 3TJ 20mm spindle ???
I'm sure you can find some tensioner blocks that will fit the swingarm, maybe from a FZR1000 if they use a 20mm spindle
				Posted: Tue Apr 12, 2011 9:43 am
				by Evilchicken0
				Hang on a minute - are you using the RD's swingarm and if so what does it look like ???
