Page 2 of 2
Re: undertray + alloy subframe?
Posted: Sun Feb 20, 2011 3:47 pm
by Drunkn Munky
2006 model shocks are the ones you want, they have a slightly smaller res. You just need to shim the top mount with 2 washers and thats it.
£60 for one, £30 for a new spring and £80 for a service = £170 for a freshly serviced, re-sprung fully adjustable shock.
Posted: Sun Feb 20, 2011 3:55 pm
by gonzothegreat
sounds like a good deal to me, off to fleebay now....
Drunkn Munky wrote:2006 model shocks are the ones you want, they have a slightly smaller res. You just need to shim the top mount with 2 washers and thats it.
Posted: Sun Feb 20, 2011 3:56 pm
by gonzothegreat
Posted: Sun Feb 20, 2011 4:12 pm
by Drunkn Munky
if you get stuck for a decent one i have one i'll be taking off next week, only to replace with another 600RR shock, just a WP fusion one
Posted: Tue Feb 22, 2011 3:32 am
by razor400
will a cbr900rr shock fit the same as a 600? I've seen one on fleabay, and did a bit of research and apparently they have a 850lb spring as standard, if this is true then would it need revalving?
Posted: Tue Feb 22, 2011 8:51 am
by Drunkn Munky
No the mounting points are wrong, you'd probably get away without revalving a standard shock for a 800lb spring
Posted: Tue Feb 22, 2011 11:34 pm
by razor400
cheers for the reply, I'm 13 stone plus gear so i guess I'd need to go for a 850 spring? although i know fuck all about the dark art of suspension, i just know that my shock is fubar and need to replace it cheapish.
Posted: Wed Feb 23, 2011 10:44 am
by Bike_Nut
Glad to hear the lightweight subframe can keep the undertray as my mods need it. My bike is mostly used for track days but I sometimes ride to them.
I have fitted a removeable no plate and lights at the back with a race seat so when I get to the track its just 2 bolts and a quick connector. All can be reversed as it plugs into the existing loom, no cutting. Just need the ally subframe now!
http://img291.imageshack.us/img291/1842/vfrc.jpg
