Relay mod for nc29
- Davez29
- Bike owned: NC29 forever
Re: Relay mod for nc29
First, sorry just realised this post should have been in cbr tech, not cbr general, doh!
Thank you for the extra info zul, it is invaluable to see a picture of what you have done and now feel confident that I stand a chance of not frying my wires when I turn on those Philips X-treme bulbs that I have been itching to try out.
Thanks chaps I will let you know how I get on.
dave
No problem, I sometimes create order out of (my) confusion, hopefullythunderace wrote:Sorry, my misunderstanding. The terminal setup you originally stated confused me.
I will take that onboard and do this the way you say as at least it will be wired just for this relay, no other influence and risking overload, I was in theory just trying to match the original feed as shown in vsource.thunderace wrote:I personally wouldn't take a feed from the high beam relay. The cabling to that relay will only be designed to carry the current for the high beam bulbs. By adding the low beam, even though they operate low on, high off and vice-versa, there is the danger that the switching between high and low will cause a surge on that circuit. I would still opt for a completely independant supply direct from the battery as I said above.
zul_cbr wrote:this is roughly what i did...
pic : http://img218.imageshack.us/img218/5006/relaymod.jpg
the white wire (headlight) is connected by a connector from the main loom and switch loom.
i detached the connector, and tap relay wire (86-pin) to white wire (switch loom) and relay wire (87-pin) to white wire (main loom).
both white wires stay detached from their connector.
from my understanding, what u want to do (to the white wire) is the same thing that i did. correct me if i'm wrong.
dave
- Davez29
Ok just done this mod and it does appear to work (nice click when the relay works), so thank you to thunderace and zul_cbr for putting up with my confusing questions.
I used thunderace's recommendation of a seperate power lead and fuse, I also took note of zul_cbr's way of splicing the 86/87 leads, thanks lads.
Now to put the bits back on and tidy up.
cbr400rrn
- Bike owned: NC29 CBR600F
Photos or it didnt happen
- thunderace
- Bike owned: R6, YZF600R
cbr400rrn wrote:Photos or it didnt happen
+1
- Davez29
If you think im going to pull all that wiring out again...thunderace wrote:+1
Believe me it worked first time, no problems, well apart from the fact I have the relay wrapped in a cut down black plastic bottle until I can find a rubber boot to keep it waterproof
Not been out yet but from what I can see the Phillips extreme bulbs are at least 50% brighter and whiter than the Honda ones, dont think they are as bright as the HIDS I had on but at least I will be legal with these and give a better light than OEM. Cant wait to check em out on my way from work down those dark country lanes, Thursday morning.
cheers
zul_cbr
- Bike owned: 1990 CBR400RR-L NC29
Anyway, its good to know that the pic make sense to someone.Durka Durka wrote:cbr400rrn wrote:Photos or it didnt happenIf you think im going to pull all that wiring out again...thunderace wrote:+1
Believe me it worked first time, no problems, well apart from the fact I have the relay wrapped in a cut down black plastic bottle until I can find a rubber boot to keep it waterproofI also need a few spare fuses before I do my commuter thing, just in case.
cheers
Arin
What amp relay should be used? 20 or 30. Only ask as i. Have a 30a sitting around
Thx
Thx
amorti
- Bike owned: CB-1, MSX125
Two bulbs at 60w = 120w, divided by 12v = 10A max continuous loading (there will be a spike at startup). So use anything from 15A wire and relays, upwards. There is no such thing as too thick unless you are counting grams, pennies, or have trouble routing the wires where they need to go.Arin wrote:What amp relay should be used? 20 or 30. Only ask as i. Have a 30a sitting around
Thx
Think of wire as like plumbing pipe. Too narrow will limit flow until the excess pressure makes the pipe pop. Too thick will not cause you any problems at all.
