is the fzr 400 3en2 stem same as r6?
- Bike owned: FZR4
Re: is the fzr 400 3en2 stem same as r6?
i also have an fzr 1000 stem early 88 its more heay duty than the 400 and same length and same thread pattern
and there not welded so i'll take the 2 and see what fits best
There are differences between Blu Spot calipers too mainly the piston sizes, some have one smaller, one larger others are two larger. Sometimes dead stop brakes are too much and you find you over brake for everthing, loosing valuable corner speed
- Bike owned: FZR4
3en2 stem was same as r6 stem so pressed in fine no machining needed, the fzr 1000 stem was few thou smaller and just slotted in, which was no good for anyone interested
now i have to make a collar for top yoke!
- Kayla850
- Bike owned: Sunn Tzar S2
Brill! It's good to hear it was pretty painless. I bet you can't wait to try the better forks outEZMOTO wrote:3en2 stem was same as r6 stem so pressed in fine no machining needed, the fzr 1000 stem was few thou smaller and just slotted in, which was no good for anyone interested
www.projection-racing.com
www.pjcfasteners.com
- Bike owned: FZR4
no cant wait , they feel so much smoother, anyone know stock spring rate for the 2000 5eb forks?
- Bike owned: FZR400RR 3TJ, RF900R
I had a quick look in the '99-'01 R6 manual and found this, should be useful to you.
Spring rate (K1) - 7.5 N/mm (0.75 kgf/mm)
Free length - 251.8 mm - Limit - 246 mm
Fork oil
Recommended oil - Suspension oil “01” or equivalent
Quantity (each front fork leg) - 476 cm3
Level (from the top of the innertube,
with the inner tube fullycompressed,
and without the fork spring) - 107 mm
Fork oil
- Bike owned: FZR4
thanks bud, just what i was looking for
