Differences between NC30 and NC35 carbies?
Cammo
Re: Differences between NC30 and NC35 carbies?
Post by Cammo »
jonno92 wrote:i've got a Haynes manual, Cammo. Just wanted to make sure I have everything down pat before I take my bike apart and start messing with important components..
Will http://www.showandgo.com.au have the gaskets cheaper? No, they're a Honda part
As I said, I'd rather replace the gaskets regardless of whether they are completely gone or not. I'd rather be safe than sorry! Rick Oliver sells reproduction nc30 gaskets for 6 pounds a set. Maybe they fit nc35, the float bowls are very similar but maybe not quite the same, perhaps ask Rick. If you reuse the old gaskets make sure the float bowls go back on the same carb they cameoff (only work on 1 carb at a time).
What should I be paying for a carby balance? Depends on what other work you're getting done, rejet, dyno etc. Just ring them and ask, they'll know how much time will be needed.
Can I take the carbs to my local bike mechanic for this, or would I be better off taking it to RB Imports as they are specialists in these bikes?.. RB Imports every time mate.
