Page 2 of 2
Re: NC30 1990 STANDARD CARB SET UP
Posted: Mon Aug 16, 2010 8:40 am
by hunter
I think you need to get yourself the haynes workshop manual,
It will help you a lot.
Posted: Mon Aug 16, 2010 10:19 am
Just get a set of vaccumn gauges, drill bits work ok to an extent but they don't take into account vacuum levels in the carbs, which vary.
It's a doddle with the morgan carbtube.. attach 4 houses and turn 3 awkard screws, especially when you consider your supposed to balance / check the carb balance every 8000km.
http://www.factorypro.com/tech_tuning_p ... edure.html
Step by step guide on float-heigh adjustment
Posted: Tue Aug 17, 2010 8:10 pm
by uber pikey
Posted: Tue Aug 17, 2010 11:26 pm
by Cammo
uber pikey wrote:
P.s. As a quick tip when it comes to refitting the float chamber bowls I didn't get any sealant so instaed I sanded down the jointing surface with wet and dry which gave me that little extra in the old seal, works a treat.
Nice one.
Since writing that guide I've had the joy of using several of Rick Oliver's replacement float bowl gaskets. Great substitute for the original gaskets and much cheaper. I think this is much preferable to using gasket sealant as this can sometimes contaminate the float chamber interior.
Posted: Wed Aug 18, 2010 11:08 am
by uber pikey
I was also scared of that, that's why I decided to skim a little of the bowl surface of so that the old seals had chance to re-seal if you know what I mean, I wouldn't do it often though.
Posted: Wed Aug 18, 2010 11:18 am
I just screw them back together.. they dont' leak often
Posted: Wed Aug 18, 2010 10:02 pm
by uber pikey
I have put it all back together ready for the MOT, I have taken pics of her and posted them in the new members intro forum for you to have a look and see what you think.
She's filthy dirty (just how I like em fnar, fnar) at the moment but will be cleaned up soon.
