PLEASE HELP AT MY WITS END GSXR 400 SP (none starter)
Re: PLEASE HELP AT MY WITS END GSXR 400 SP (none starter)
hi there yes got the orings from you all put in correct i have had the carbs out 3 or 4 times and checked everything again but still will just not fire.
sounds like it wants to fire but drains the battery before it will start. have checked all the plugs are firing but not sure if they are sparking enough.
got the plugs set to 1.5 turns out not sure how to adjust the float as i havent touched these before.
i believe the floats have to be set to 20mm is this correct?
it will be a great shame to strip it cause the bike is in mint condition. if i knew it was definatley the carbs i wiould pay someone to set them up for me.
but just didnt want to spend £200 to have the carbs set up and it wasnt them in the first place.
ANY HELP AT ALL WOULD BE VERY MUCH APRECIATED. I HAVE SPOKE TO STRIPES AND HE HAS RUN THROUGH A FEW STUFF TO CHECK WHICH I HAVE DONE PUT STILL THE SAME.
