Skinnydog0_0's NC35
skinnydog0_0
Bike owned: Penny Farthing
Re: Skinnydog0_0's NC35
Post by skinnydog0_0 »
CMSMJ1 wrote:Hows about fitting an electric water pump and moving the unit to the side?
Bike does look nice man!
Some of the aftermarket systems have front pipes that are sligtly offset. I'll check my photos and see if I can find one. I recall my HRC mild steel system burned my lowers in a new place...so that might be the one I was looking at.
Thanks,
How does the electric water pump fit to the bike as i have never seen one on?
Yes i have been looking for ages at different pipes but unless you have them in your hands or someone else has and measured them against standard it's quite hard to tell. I have seen some nc21 downpipes on fleabay, they look like they may fit, and only £15ish for the pair, so might give them a go :grin:
skinnydog0_0
Hadies wrote:Respect for getting back on man! Good luck with with everything!
Thanks :peace:
skinnydog0_0
Cammo wrote:Cool solution to your riding dramas, respect! :peace:
It looks like quite a bulky unit, is it just a 12v i/o solenoid? If so, there are smaller solutions available.
I can't quite get my head around the pics of your gear change setup ( :sshh: ). Why not go for a full electronic up/down change via a solenoid actuator? Quite a simple setup, this would remove any input from your left foot.
I reckon there's enough space under the engine for a decent strength solenoid, it might pay to talk to a smart auto elctrician, I'm sure there are other options to your current setup that will allow full riding freedom.
Hi Cammo,
Thanks, yes the unit under the water pump is a 12v actuator that is operated via 2 bottons on the handlebar. this has a control unit that can be wired to R.Os' Ignitec CDI to cut the ignition, for better/smoother clutchless gearchanges.
With my setup i still dont use my left foot at all :P but have to use the clutch on the downshift.
I have been looking for a smaller solenoid or actuator but to get one that has enough power and is fast enough isn't very easy.
The unit i have changes in around 30 - 50 milliseconds and has a push/pull power of 30Nm at the end of the stroke. I have found smaller units but they are slower and not as powerful.
There is another company (proshift) that use this type of system and are more race focused, i may give them a try see if they can offer me any advice or parts that may help with the mounting. Or i might just get them to fit one of their units in a place that will be out of the way :grin:
