Re: 3tj repair and service
Posted: Sun Jul 04, 2010 8:09 pm
Clean the carbs and the brake calipers .... I'm in a rush I'll explain it tomorrow
Take the carbs off the bike. clean the outside of the carbs with some cleaner / parrafin / petrol and layout a large sheet of white paper (so you can find and bits you might drop).
Take one of the carb tops and float bowls off at a time. Use a 1/4" ratchet and a bit that fits the screws press down hard and then move the ratchet. when the torque breaks don't unscrew but go to the next screw (this is so the bowl / top doesn't more pressure on the other screws). When you take the top off there's a big spring under it so it will want push the top off a bit, be carefull because it holds the needle in place. There's a rubber diaphram be careful with it and ease it off - check it over and lift it and the slide out. Now clean it all with carb cleaner and a clean cloth.
Now turn the carbs over and take the corresponding float bowl off. because your bike is running you probably don't need to fully strip this, have a look in the bottom of the bowl and clean any residue out then do the same around the floats. Spray some cleaner through the jets - don't push anything into them. Reassemble the top and then the float bowl - put a little copperslip on the screw threads and don't over tighten the screws.
Repeat for the other three and put the carbs back on the bike
A tip is to attach the throttle cables before putting them onto the rubbers. Put the bike in gear because you need to push the carbs a bit to get them to seat. Make sure that they are on properly before you do up the reatining clips.
