Page 2 of 3
Re: NC24 Jetting, apologies in advance !
Posted: Thu Apr 22, 2010 6:56 pm
by Old Painless
The cylinder head and cylinder are part of the crankcase ? Thats a bit odd. Im sure i saw a gasket there. lol
I'll have to go and have a look incase i'm going crazy.
Posted: Fri Apr 23, 2010 6:05 pm
Old Painless wrote:The cylinder head and cylinder are part of the crankcase ? Thats a bit odd. Im sure i saw a gasket there. lol
The cylinder head comes off.
The barrels are part of the crankcase. (split horizontally)
The head-gasket you will struggle to get but you can adapt an NC30 one with ease..
Posted: Sat Apr 24, 2010 6:52 pm
by Old Painless
Having pulled it apart i have seen the way its split. Pity the barrels are attached to the crankcase as mine are damaged. bah.
Posted: Sat Apr 24, 2010 6:59 pm
Old Painless wrote:Having pulled it apart i have seen the way its split. Pity the barrels are attached to the crankcase as mine are damaged. bah.
It's a Honda thing!
Makes you appreciate the ZXR's just pull off.. mind you on the ZXR you need to pull them off more than usual.. with the hondas they usually last :)
Posted: Sun Apr 25, 2010 11:56 am
by Old Painless
I appreciate i am just unlucky this time round. :)
Posted: Sat May 01, 2010 4:59 pm
by Old Painless
The manual lists 2 turns out on the pilot screws but i can seem to see any on the carbs, does anyone have a picture of the location ?
Posted: Sat May 01, 2010 8:14 pm
There on the inside of the carbs
[1].-.[2]
[3]'-'[4]
If you look into them they'll be quite high up where the .'s and ''s are :)
I use 2 as a base setting.
I think mine range from between 2.1/8 to 2.5 out depending on bike.
Posted: Sun May 02, 2010 11:32 am
by Old Painless
Is this looking from the top down or bottom up ?
Thanks for the help.
Posted: Sun May 02, 2010 7:57 pm
There on the inside Sides.. so it's looking from the outside side inwards.
Posted: Sun May 02, 2010 10:21 pm
by Old Painless
Great stuff, thank you.
Also, is this the correct way to derestrict the speedo ?
