freebie 3tj speedo restriction modification
Re: freebie 3tj speedo restriction modification
Post by Evilchicken0 »
If you stay on the forum long enough you'll find the same questions come up ;)
petrolhead
Post by petrolhead »
Ummm thats interesting about the 4DX CDI....
I have a 4DX and a 3TJ CDI here but the wiring is different on the 4DX one is it possible to make it fit the 3TJ or does it involve internal work to the CDI.
The 3TJ CDI in the 4DX will restrict because it won't get the "0" signal from the speedo. If you can get a M-Max box that connects into the 3TJ CDI you'll be ok or you could have the 3TJ CDI molested
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
petrolhead wrote:Ummm thats interesting about the 4DX CDI....
You can plug your 4DX cdi into your 3TJ loom to get rid of the restriction :grin:
www.projection-racing.com
www.pjcfasteners.com
