Page 2 of 2
Re: Carb Rubbers, where from?? Rejet??
Posted: Fri Mar 05, 2010 8:03 pm
by graham72
Ok, so ordered R O needles and float bowl gaskets from Rick, been to local dyno place and got new 118 and 120 jets.
According to Rick I don't need to add extra washer under needle with his needles, just use the original one.
Do any o rings need replacing while I do the mods, just want to make sure I have all the bits I need!!
Posted: Sat Mar 06, 2010 10:08 am
by alexwitham
Just the float bowl gaskets.
Posted: Wed Apr 07, 2010 9:47 am
by Mr_Fen
Polisher wrote:I tohught that mine was running pretty well until I drilled the slides, re jetted it and put the RO needle in.
BLOODY HELL what an improvement! that's all I can say!, well worth spending seventy odd quid with Rick and a few hours work following Cams carb guide
what tools/kit do you need to drill the slides? is there a photo guide online somewhere for this?
Posted: Wed Apr 07, 2010 8:17 pm
by Polisher
what tools/kit do you need to drill the slides? is there a photo guide online somewhere for this?[/quote]
Really is more simple than people think. When you take the slide out, you'll see a tiny hole in the end. Just drill this out using a 2.5mm drill bit. I was a bit aprehensive at first, but armed with a cordless drill it took less then 5 seconds. Just make sure that you blow out all the plastic swarf.
If you look at Cam's Carb guide there are pics there ... somewhere
Posted: Fri Apr 09, 2010 11:53 am
by Spike16
make sure u take the needle out when you driling the whole or ul drill a whole in the plastic bit that holds the needle in aswell
