engine help on swaping
sparkles
- Bike owned: 1990 fzr6 3he with a 4jh engin
Re: engine help on swaping
Dont know to be honest as dont know a way of measuring it to find out
With in a week of adjusting chain its stretched again because of trhis i tend to leave it as it is but mind you chain was on bike when i got it 5 years ago
You can use a laser tool ... but it's £50. I got one to use on the Bimota because there's no marks for the chain tensioning. probably a bitsteep for what you need. You might ask around at a garage to see if they have one you could use, or they might be able to tell you how much you need to offset the sprokets by.
How far back are the tensioners ? The chain could be knackered, they don't hold their tension when they're nearly dead.
sparkles
Chain needs replacing and is nearly as far back as it goes on tensioners
One guy i came across uses EP90 (gear oil) to lube his chain and has had the same chain for 3 years
So ???sparkles wrote:Chain needs replacing and is nearly as far back as it goes on tensioners
As long as the chain is kept clean, correct tension and lubed it should last ... for as long as it's life is. Different chain's have different life spans depending on their construction, the bike they're on and the kind of rider. That somebody uses one type of lube over another isn't so important. Chain oilers do seem to work though.
If the sprokets are out of line you'll be putting a sideways stain on it which will cause it to wear premeturely.
sparkles
Just won this on ebay
YAMAHA FZR600 GENESIS 3HE 1991
CHAIN AND SPROCKET SET
SPROCKETS AROUND A 3RD WORN BUT STILL GOOD FOR A FEW THOUSAND MILES , CHAIN NEARLEY NEW. DONE JUST OVER 300 MILES , STILL TIGHT AND IN VERY GOOD CONDITION
GOOD WORKING ORDER
USED CONDITION
Sold For: £24.99
Postage: £9.99 Royal Mail 1st Class Standard
Mt rear sprocket i repl,aced near the end of last year
GOOD WORKING ORDER
USED CONDITION
Sold For: £24.99
Um ... the front sprocket looks worn.
I suppose if there's no offset to them you can clean and fit them backwards so the unworn teeth are driving.
sparkles
Not bothered about sprockets and i turned my rear one around today
Reason i bought it is because of the chain has done about 300 miles and would be about half price to a new one
Im not working so have to be tight on money
300 miles ??? they meant to say 3000 but the sprokets look more wear.
I hope it's just the picture and the chain is ok
sparkles
I got chain and sprockets less then 24 hours after paying for them and they are now fitted after having to take swing off to fit chain all because the tool for chain i used broke but glad i did as found bolt at top of rear shock loose
Chain is nice and tight and sprockets are ok and show some wear
looks like ill have to go throw bike and use thread lock
Cool - glad it was ok.
Maybe you just need to check the torque of some nuts and bolts, good excuse to clean and grease the linkages
