my 2tk wont rev up (will now shes fixed)
Re: my 2tk wont rev up
Post by Evilchicken0 »
pastures16 wrote:emulsion tubes :oops:
The bit the needle drop into. They can go oval which means you can chase the mixture all over the place and still it goes out of tune.
For road though the 3en's CV's should be fine
hipringle
Bike owned: 954 blade,
Post by hipringle »
Piggin thing, had the carbs off again & the tubes look ok to me. tommorow if I get the chance I,ll take the carbs off a running fzr & swap them over, oh & recharge the car battery tonight......
awwwwwww bless :grin:
hipringle
Post by hipringle »
Lol I know, was freezing cleaning windows this morning then stood outside in the cold with a bike that wont run, doesnt get any better :lol:
pastures16
Bike owned: 2tk virago vx 750
Post by pastures16 »
is that a little brass insert that you can see when you look into the carbs
if so ive noticed on no 2 and 4 carbs its pouring out take it thats not normal then if so whats the fix for it
pastures16
bump :drool:
hipringle
Post by hipringle »
yes thats the bit, its a longisg brass tube that goes thru the carb, not sure how much petrol should come out of them.
pastures16
whats the fix for it can you get the parts still
hipringle
Post by hipringle »
Well its the same problem with the other carbs on, it just wont run & rev, it tries sometimes to run but thats it.
Boris I swapped the cdi over from a 3en2 as the 3en1 cdi has blocks of 6 & 8 connectors, the 3en 2 has the same 4 & 6 but also has extra wires coming off as well. The cdi I plugged in doesnt give a spark so it really has to be another off a 2tk I think :down: .
Thing is the original cdi gives a spark so I,ve no idea why it the bike wont run, super compression, spark & fuel so I cant work it out!
I,ll probably end up selling it for spares if I cant sort it shortly.
hipringle wrote:Well its the same problem with the other carbs on, it just wont run & rev, it tries sometimes to run but thats it.
if you've got sparks, air and fuel then the timing might be out? Are the coils talking to the right plugs mate?
pour a gallon of fuel on it and flick a cigar......that'll get it going.
