Fzr400 2TK Pulling Away And Starting Problem
pastures16
- Bike owned: 2tk virago vx 750
Re: Fzr400 2TK Pulling Away And Starting Problem
where is this chap evilchicken0
Fzr400rr 3tj Danny
- Bike owned: FZR400 1WG 2TK
Yeah iv noticed some times mine doesnt go back down to normal idling speed some times but i swear these bikes have a mind of its own i was drinking a cup of tea while the bike was idling and next min it went up to like 4-6k revs so quickly went to the bike turned the idling screw down a bit and it went back to normal :S now im thinking my carbs are dirty but wouldnt that make the bike play up loads more?[/quote]
i do the same it will go to tickover the rev it again let it drop and it stalls[/quote]
Have you found when pulling away its very weak and 9/10 it will stall? and probably have to use alot of clutch to get it going?
Fzr400rr 3tj Danny
Im not sure but iv been reading through loads of forums and he knows his stuffpastures16 wrote:where is this chap evilchicken0
pastures16
havent got that far to riding it yet m8 only just got it spairs or repair so im on a learning curve at the min when ive got it running right i will start restoring it have you any pics of yours m8 mine are here http://s40.photobucket.com/home/pastures16/index" onclick="window.open(this.href);return false;
Fzr400rr 3tj Danny
Ah pretty cool mate, yeah im on a learning curve to im only 18 and i learnt by myself or this website lolpastures16 wrote:havent got that far to riding it yet m8 only just got it spairs or repair so im on a learning curve at the min when ive got it running right i will start restoring it have you any pics of yours m8 mine are here http://s40.photobucket.com/home/pastures16/index" onclick="window.open(this.href);return false;
Yeah i have another forum>>> http://www.400greybike.info/newforum/vi ... w=previous" onclick="window.open(this.href);return false;
Your fzr looks pretty nice mate
hipringle
- Bike owned: 954 blade,
I havent ridden my 2tk yet either but by the nature of a close ratio box they have I,m sure first gear will be pretty tall & will need lots of clutch slipping.
hipringle
rubber is his specialityFzr400rr 3tj Danny wrote:Im not sure but iv been reading through loads of forums and he knows his stuffpastures16 wrote:where is this chap evilchicken0
Fzr400rr 3tj Danny
The bike was running alright then it died on me when i came to a stop, so i pushed it to the pavement waited 10 mins and it ran alright just not as quick, then died bit later and same happend then i didnt wanna ride it home then couple weeks later tried bumping it, wasnt having any of it, got it picked up, then after cleaning bits up etc bike was running better, then driving it it saw a couple of scooters and no joke it felt like the bike suddenly just went into hyper mode the bike had so much power, then i went back home and it died in low revs, then 2 back fires then it started, and yeah lol it rode alright after the back fires but its just the low revs i think it doesnt likehipringle wrote:I havent ridden my 2tk yet either but by the nature of a close ratio box they have I,m sure first gear will be pretty tall & will need lots of clutch slipping.
Obviously the first thing I'd say is check the compression.
This is get an idea of the condition of the vavles and piston rings your best starting here.
Easier though is to check your float bowl gaskets aren't flat ... they can leak a bit causing the fuel pump to need more time to prime (the ticking noise at start up).
How's your exup ??? do the cables have any free play - you should have no play but equally the cables musn't be tight.
Is the fuel tank dirty ?
is the fuel filter on the top of the fuel tap dirty ?
Can you swap the ciols for the 3TJ's to check them ?
Back firing can be a weak mix as well as rich.
Quickly rising idle speed is a weakening mixture, classically running out of fuel
could be a blockage or an air lock.
How old are the carb rubbers ?
Do the checks, do a compression test, take it to a dyno
Fzr400rr 3tj Danny
How much are compression testers? or getting a dyno? The bike doesnt pull away it might do if i clutch alot more, and ill check as much as i can tomorrow and ill give you guys and update Cheers evil =]Evilchicken0 wrote:Obviously the first thing I'd say is check the compression.
Also would this one be alright to use http://www.halfords.com/webapp/wcs/stor ... yId_165557" onclick="window.open(this.href);return false;
