Valve clearances need help
Re: Valve clearances need help
All sounds about right to me
Strikmabill
Contacted yamaha today, each valve shim will cost me 8,16€ and I'll have to get all 8 for intake... And should I change the valve cover gasket? My old one seams fine but I don't know if it'll hold once it goes back on. Tryed a telescopic magnet today but had no luck, I'll have to drain the oil and remove the oil sump to get that little s*** from in there.
buzzawak
Try ringing around your local bike dismantler / wrecker. Often you can just swap the one you have for the right size and pay a minimual service fee. The shims dont wear out.Strikmabill wrote:Contacted yamaha today, each valve shim will cost me 8,16€ and I'll have to get all 8 for intake... And should I change the valve cover gasket? My old one seams fine but I don't know if it'll hold once it goes back on. Tryed a telescopic magnet today but had no luck, I'll have to drain the oil and remove the oil sump to get that little s*** from in there.
Strikmabill
There aren't many around here and the ones that do exist sell forks tanks and complete engines. It would be really hard to find just the shims around here, still worth a try though. I'll see what I can find. Thanks.
Taggyd
try ebay aswell!! some shims on there at min i think
Strikmabill
Already found them on ebay, waiting to know price and shipping costs. Will phone two brakers I know though. Thanks.
Strikmabill
As long as I have the carbs out I thought I'd give them a clean and found the rubbers are pratically all broken and dry. anyone know where I can get some? Called yamaha and there's no 'restoration/all new rubber' kit available. Is my only option trying to find similar ones at a plumbing/hardware store?
Taggyd
try searching for the carb make aswell, i found a great site but it's in my favorites at home and not on the work comp!
had all of the gibbins assosciated with carbs and pretty sure the gascet/seals aswel!
the carb to engine rubbers ... hard to find.
But try Thundercat ones - I don't know if they'll be the csame but they use a similar carb and engine block
Strikmabill
Not the carb to engine ones. The ones between carbs that carry the fuel from inner to outter carbs and the ones in the middle, with the T piece that connects to the fuel line from fuel pump.
