RVF Race Wiring harness
Cammo
Re: RVF Race Wiring harness
Post by Cammo »
indiaguy wrote:I
The r/g wire from the starter relay goes to gnd via the clutch switch or neutral switch.
Though you were talking about 2 wires here, my mistake...
Just join the 3 wires at the cdi and run 1 of them to -ve.
Indiana Jones
Bike owned: XT600Z,'10 TE250 ,XS650 chop
Post by Indiana Jones »
I can join the two earths for the sidestand and neutral switch and use this to cut the ignition when changing up,quick shift style.
Breaking the earth to the cdi with a make/break switch on the gear lever.
It's old skool.
Who else has done this?
J.B.
Post by J.B. »
Missed these replies to my original post, thanks very much for the Race Harness diagram. I've been running a stock harness on the track bike up till now but as I'm about to change the body work I'll do the harness mod at the same time.
Question: am I right in thinking that I only need to run the orange/blue wire from the CDI to +ve if I'm running the street CDI and with the HRC CDI this is unnecessary? What about the Ignitech?
Thanks in advance,
JB
Cammo
Post by Cammo »
JB wrote: Question: am I right in thinking that I only need to run the orange/blue wire from the CDI to +ve if I'm running the street CDI and with the HRC CDI this is unnecessary?
Yes. Not sure about the ignitech.
J.B.
Post by J.B. »
Cheers.
stevenlee0710
One Hit Wonder
Post by stevenlee0710 »
Hello guys, i know this post is old. But what does -ve and +ve mean?
Sent from my SM-G930F using Tapatalk
Bike owned: VFR400
Post by magg »
-ve means battery negative terminal, usually connected to the chassis. +ve means battery positive terminal or the supply voltage distributed to electrical components.
robertRVF
Bike owned: RVF, NSR, NS400R, RZV500R, Mit
Post by robertRVF »
L.Svedberg wrote: Fri Nov 13, 2009 7:11 pm here you go
Been looking for this for a month. Wow a piece of gold info here thank you.
