NC30 Boffin's, Help Required.
- alexwitham
Looking to tinker with my carbs within the near future and thus requiring the removal of the crankbreather hose which goes from the crankcase housing to the bottom of the airbox, anybody 100% sure what the external size of the crankbreather outlet is so I can pop on a k&n type filter? i.e - similar to this - http://www.wilcodirect.co.uk/index.php? ... ts_id=4060" onclick="window.open(this.href);return false;
Thank you kindly.
Thank you kindly.
mart
- Bike owned: sp1, sv650, nc30
Re: NC30 Boffin's, Help Required.
pretty sure the connector is 15mm (not 100% sure though)
Are you removing the airbox then?
If so, why not go for a hose to catch tank and do it pukka style as shown in Martin's bike build thread?
Or do it cheap style, like me, and use a hose to the frame castings and breathe into that?
- alexwitham
Correct, Im just playing with a few ideas over winter.Are you removing the airbox then?
(It was 15mm, thanks Mart).
I've put on a K&N Crankcase filter for the time being, it will also stop hot/oily air mixing with the nice cool air coming in through the snorkel. Every little helps
A catch tank isn't on my 'top-do-list' yet. Until my engine gets covered in oil, then I may have to sort one.
Thanks fellas.
garden hose into a pop bottle?
- banoffee
have got the same setup on my gsxr as have lost the airbox. it really stinks when hot
