NC30 sidelight bulbs
graham72
Bike owned: NC30,
Re: NC30 sidelight bulbs
Post by graham72 »
banoffee wrote:might be worth posting pics up when you have it apart? happy to compare etc to try and help.
were your sidelight bulb holders the same, rubber with the bulb set quite deep so only the very top of the bulb can be seen?
jamie125
Post by jamie125 »
Mine were, I used some small pin nose pliers and gently pulled the old ones out. You can pull the rubber holders back a little aswell to help.
banoffee
Post by banoffee »
graham72 wrote:were your sidelight bulb holders the same, rubber with the bulb set quite deep so only the very top of the bulb can be seen?
yep
ibby4585
Bike owned: SP's
Post by ibby4585 »
Right, received the new bulbs today, and they fit both bikes side lights perfectly. i have now tried the instrument panel bulbs with the remaining 3 wedge ones i bought and they fit (just) and light up!! i will wait till night time and take some pics. the temp bulb and the rev counter, speedo are slightly different sizes. so the pic you will see will be the temp, and rev counter on led and the speedo on the normal bulb!! :grin: finally!!
banoffee
Post by banoffee »
at last :grin:
ibby4585
Bike owned: SP's
Post by ibby4585 »
i know im pathetic arent i! you should see me with the xmas decs!! a master!!!
banoffee
Post by banoffee »
ibby4585 wrote:i know im pathetic arent i! you should see me with the xmas LED lights!! a master!!!
corrected for you ;)
royster81
Post by royster81 »
my only worry is they are too bright and end up distracting at night,i've turned the dash lights down on my car at night and it's far easier to drive than with then fully lit up.
couple that with the white speedo/temp/tacho dails Mr Fen is selling and it'll be like your driving down the road with a disco in front of you.....
but hopefully not ....
ibby4585
Bike owned: SP's
Post by ibby4585 »
yeah v.true, we will give it a try and see what its like. hopefully they are just a bit brighter than the standard ones!
ibby4585
Bike owned: SP's
Post by ibby4585 »
Right i am now going to download the led pics. Warning please wear sunglasses!!!!!!!!!!!!!!!!!!!!!!!!
As you probably guessed they are shite!! they do shine through but give off very low light kind of a cloudy look!!
