HID ballast kits info
leopard_pagan
Post by leopard_pagan »
here are pics of what i have on my NC29.
Bulb type: UK H4 Hi/Lo (dip and main beam in one bulb)
http://i18.photobucket.com/albums/b145/ ... ghtMod.jpg" onclick="window.open(this.href);return false;
Bulb temperature: 4300K White
the kit i bought has 2 ballasts, 2 H4 bulbs + harnesses.
http://i18.photobucket.com/albums/b145/ ... r09-27.jpg" onclick="window.open(this.href);return false;
difference between normal bulbs and Xenon HID
Electrical specifications for 12V ballasts:
Normal operating input voltage range: 9V - 16V
Time limited extended operating input voltage range: 6V - 18V
Starting input voltage range: 8.5V - 18V
Nominal output power: 34.5W 1W
Low output power setting: 25W 1W
Maximum run up output power: 75W
Maximum run up lamp amperes: 2.0 A
Maximum inrush current at 13.5 V: 8 A
Efficiency of D1S and ballast at nominal supply:87%
Ballast unit efficiency: 89%
Output steady state frequency: 4.5 KHz
Operating temperature range: -40 to +105 C
where i fitted my ballasts. please note that mine are quite large compared to what is available today. i do intend to move them under the pillion seat this winter by extending some wiring.
Also for those who want to mod their headlight units to accept H4 bulbs with out butchering them.
PLEASE NOTE THIS IS FOR THE NC29. i do not know if this will work on a NC23! nor will i be responsible for anyone who feks up their headlights!
Last edited by leopard_pagan on Thu Jul 15, 2010 12:29 pm, edited 4 times in total.
Metelko
Re: HID ballast kits.. info.. pics (sticky?)
Post by Metelko »
Thats a big help thanks !! Ill probably get those adapter rings from fleabay hopeing itll save me doing any mods :)
Davez29
Bike owned: NC29 forever
Post by Davez29 »
I think its worth noting as the picture above shows that the K rating does not mean they are more powerful, its the colour temperature of the bulb, so as the sun is around 5500 K on a sunny day you wil find that 6000k is the closest being bright white but if you find that too harsh (as its more of a photo flashgun temp) go for 4500k which will give a slightly warmer tint. Go higher you will get that familiar blue light that most boy racers tend to go for.
Metelko
Post by Metelko »
what dimensions are your ballastsas the ones i am looking at getting are a slim version 13mm depth 64mm width 85mm length? Are they much smaller than the ones you have?
leopard_pagan
they will be yes.
yours should be 1/2 to 3/4 the size of mine.
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Do the ballasts not need a flow of air running over them i.e do they get hot? reason i'm asking is will they be ok mounted as you are planning on doing by putting them under the seat.
Was the wiring from the ballast to the bulb long enough and from ballast to wherever they get the positive/negative feeds from or did you have to modify them?
Cheers Karl
leopard_pagan
they dont get hot, its a myth.
the kit i bought were designed for a car, so some of the loom is long (well hidden wrapped around the headlight brackets!), but i will need to cut/lengthen some if not most the wires. i will be soldering (with lead solder!) every joint + using glued heat shrink to seal the joint. + test to make sure it works!
leopard_pagan
soooooo... here we are again.. lol
Rode home in the dark this week. i must admit i am kinda disappointed..!
My lights dont seem as bright as they used to be. they dont light up as much of the road as before...
so.. this leads me to one conclusion.. the ballasts break down over time! why the ballasts? i replaced the bulbs 3 months ago like for like temperature. even before i replaced the bulbs i did notice a drop in light.
soooo... i am back at checking out Ebay for HIDs.. there is far more choice than when i 1st did this...
i want to get the slim basalts (old 10cm long x 3.5cm thick, new slim 8.5cm long x 2.5cm thick), same Hi/Lo bulbs (H4-3) and same colour 4-6000K
the ONLY thing i dont like is the fact i would be buying from China/Hong Kong!
Also... i have noticed that you can get 35W or 55W ballasts....
I have found that i can hot swap my old ballasts for slim ones and leave the original bulbs etc in place.....
whats the difference in 35W or 55W?
the 55W are brighter than 35W... and its only the ballasts, the rest of the kit is the same.
Davez29
Re: HID ballast kits.. info.. pics *MODS Turn in to a sticky?*
Post by Davez29 »
leopard_pagan wrote: the ONLY thing i dont like is the fact i would be buying from China/Hong Kong!
Not sure how much your going to pay but HIDS Direct Uk based does them for £65 next day delivered, on ebay the same company sells them for £69.50 :?
leopard_pagan
Re: HID ballast kits.. info.. pics *MODS Turn in sticky?*
£60 ish is the price from Hong Kong.. havnt found a UK seller yet with the right type of kit......yet.. i know new stuff pops up all the time. been a busy day today at work, family etc.
