K-Conversions fairing fitting
PARUS
Re: K-Conversions fairing fitting
Post by PARUS »
And half hour work and all kit ready. Not sure - that aluminum best material for brackets, but it just need me to be sure I made brackets correct. Will check tomorrow and maybe re-made them to something more rigid structure.
PARUS
Post by PARUS »
Under seat bracket should fir like this.
But where to fir side brackets?
Faster400
Post by Faster400 »
PARUS wrote:Hi Faster400.. Good to have you on forum. Spend all day to fit rear unit and unfortunately I can't. As you said before - I need to cut all this thing on rear unit.
Could you describe (or maybe put the picture) where and how you fit mounting brackets?
Thanks.
mounting brackets for front or rear, rear I think you have pretty much sumed up. Pics of my subframe 2moz, promise! ;) (work, need I say more....) I've no longer got kit fitted-want to go back to original so ill take pics of where to put mounting brackets but no fairing in view...
PARUS
Post by PARUS »
Thanks Faster400.
Any picture or explanation will be helpful. Because I can fit this fairing. I just only found where to fit under seat brackets and all.
PARUS
Post by PARUS »
Spent half day fitting tail unit. No result, looks like frame should be cut.. Here is a picture below
PARUS
Post by PARUS »
PARUS
Post by PARUS »
PARUS
Post by PARUS »
mik2100
Post by mik2100 »
Hi Parus, we are experiencing the same issue! I have already trimmed off the upper part of the tail unit and you know what? The fuel tap is blocked! We have to either enlarge the existing fuel tap recess or... cut the whole damn piece out! Just like in the pics u posted!
I reckon if all went well and the whole tail unit is able to fit, there will be a problem with the undertray! looks like there's alot of cutting needed to get it fit under the tail unit. I am looking into using the original NC29 undertray to see if it fits... sigh...
PARUS
Post by PARUS »
mik2100 wrote:Hi Parus, we are experiencing the same issue! I have already trimmed off the upper part of the tail unit and you know what? The fuel tap is blocked! We have to either enlarge the existing fuel tap recess or... cut the whole damn piece out! Just like in the pics u posted!
Hi mate,
I spent all day just thinking about cutting subframe and decided to fit it without cutting it. You're really right, if you cut subframe undertray wouldn't fit - that the problem. I decided to made some additional bracket to fix this fairing.
This part will be cut I think
Will post picture about progress...
