Exup bushes
buzzawak
Exup bushes
Post by buzzawak »
Hi all, anyone know the dimensions (using a micrometer) of the EXUP solid bush?
This is the bush that the EXUP valve swings on. Yamaha here wants $50 each for
something worth $6. Bugger if I will pay $50.
Morespeedvicar
Re: Exup bushes
Post by Morespeedvicar »
Hiya, i pressed a bit of brass pipe in mine a few years ago, its been ok since, but i cant remember what size it was. Sorry.
Ian
buzzawak
Re: Exup bushes
Post by buzzawak »
I got around to taking off the exup valve bushes yesterday. Looks like a carbon bush and also has a dust seal on the outside.
The size for future reference is ID 10mm x OD 17mm x 7mm
Question, what would be the best way to get the inside bush out of the exup housing?
Morespeedvicar wrote:Hiya, i pressed a bit of brass pipe in mine a few years ago, its been ok since, but i cant remember what size it was. Sorry.
Ian
Morespeedvicar
Re: Exup bushes
Hi, i dont think the one in the exup housing is bushed (mine wasnt worn that end), i just pressed the pipe in the ceramic bush in the cable end.
Ian
buzzawak
Re: Exup bushes
Post by buzzawak »
Morespeedvicar wrote:Hi, i dont think the one in the exup housing is bushed (mine wasnt worn that end), i just pressed the pipe in the ceramic bush in the cable end.
Ian
From the parts listing the same bush is used at both ends.
